GE Monogram Fresh Food Door Sticking Out
Dear Pros,
We recently moved into a new home and we realized that our GE Monogram Fridge looked a bit awkward. The Fresh food door was closed, but it was sticking out more than the freezer door. We thought it may be the hinge that is a little loose. We were told by someone that we would have to replace the entire door. The door however only comes with the steel skin. The other option is to get the door assembly that our friend John H believes would resolve the issue.
I am not sure if it is the lining in the fridge of the fresh food door or the loose hinge on the bottom or the door that is causing the problem.
Could you please help before we make an expensive purchase from Appliance Parts?
thank you
Sbhatti
