I have a GE Monogram side by side fridge. The lights in the the freezer do not work, but they work on the refrigerator side. I know it’s not the switch or the bulb. Any advice?
What is the complete model number of the refrigerator?
— Begin quote from Gene;801440
It’s model# zlss360drgss
There is the light transformers tray under the refrigerator (#549 at the [B]diagram[/B]). There are two fuses in the tray. Try to reset them and check for continuity. replace if it’s open.
- The light fuse WR23X10269
Here are the breakdown diagrams and http://www.appliancepartspros.com/parts-for-ge-ziss360drgss.html
— Begin quote from Gene;801624
There is the light transformers tray under the refrigerator (#549 at the Parts for GE ZISS360DRGSS Refrigerator - AppliancePartsPros.com. There are two fuses in the tray. Try to reset them and check for continuity. replace if it’s open.
- The light fuse [part]WR23X10269[/part]
Here are the breakdown diagrams and [URL="http://www.appliancepartspros.com/parts-for-ge-ziss360drgss.html)
That was my issue. I had originally looked there and didn’t realize there were fuses there. Thank you so much as you saved me a service call.
You are welcome. I’m glad to hear it was such easy fix.
