GE Monogram ZDP48L4gh5ss 27" Oven not heating
Last year my element on the 27" oven went out in flames, literally. It burn in half when it went out, looked like a welding rod. I replaced the element, oven heated but never got to temp. Now, it won’t heat at all, no lights under the knob when I turn it on, only the fan comes on. I have checked the high temp fuse underneath, replaced the thermostat, and the push button control board. I have 240 volts coming in to the oven, and at the push button terminal block up top. When I check the voltage at the element, I have 120v at each end of the element, but if I check the voltage between the ends of the element, I have nothing. I would think I should have 240v there. Any ideas?
