-Edit- I posted in the thread topic that the faults only happen after 45 minutes of cooking time. This is not the case as confirmed by my wife. The faults happen anytime…sometimes immediately and other times not at all.
I have been getting F2 and F3 fault codes with my oven. I came to this forum, read up and found that the temp sensor may be bad so I ordered another one from Appliance Parts Pro and installed it. Everything seemed to work fine for a day or so but now the error codes are back. F2, F3, and F5.
I’ve checked the wiring, touched all the connectors, looked for obvious items but I can’t see anything out of place. I’m at the point of replacing the ERC but I dont’t want to do that unless there is a reason. I’d appreciate any help.
Thanks!
