GE Oven Pre-Heats, then goes to self-cleaning
I have a GE JBP65GV1WH 10.1 7.6 Serial # SM222379G
that pre-heats fine, then after a few minutes, the self-cleaning light comes on and it says to pull the lever for self cleaning. The stove goes cold. Any suggestions as to what it could be?
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=JBP65GV1WH
Sounds like a control board problem.
The board looks like it is obsolete.
I would try unplugging (or shut the breaker off ) for a couple minutes to see if the board will reset itself.
