The digital clock shows the time, bot the time cannot be reset nor the timer to work. Is there any way to correct this , or is a new clock required? If so is one still available?
The clock part number is WB12K20.
If you do a google search with the number you will find used ones, places that repair the boards, and even a couple of new ones.
