GE oven won't heat past 170 or so
Oven won’t heat past about 170 or so. Broiler works fine. Replaced oven baking element…same problem. I can hear the thermostat clicking but it never achieves the higher temperatures.
Help!!!:confused:
Hi.
Please check the oven sensor resistance. At room temperature you should have about 1100ohm and if it checks OK - replace the control board.
The sensor WB23T10002
The control board WB27X10311
Here are the breakdown diagrams and http://www.appliancepartspros.com/control-panel-cooktop-parts-for-ge-jbp66by5ad.html
Post the results.
Simon.
