GE Profile Artica Side by Side
GE Profie Artica side by side refridgerator.
Metal divider between freezer and ice box is warm/hot to touch.
Last few days, the temp on the freezer side is rising from 0 to 15 -18 degrees even after reset
?? Part going bad ??
Hi.
Pull out the fridge, take off the rear bottom cover. There is the condenser coils on the right.Unplug the unit. Clean the coils really well, use vacuum, brush, spray it with deluded Simple green.
Make sure that the condenser motor is running.
Post the results.
Simon.
Simon,
Dead on…coil had a blanket of dust building up. Amazing how much dust got in there. Thanks for the help. Back down to 0 and holding.
Bruce
You are welcome.
Glad it solved the problem.
Simon.
