Model: J S998B0H1BB
S/N: DG2 69166 Q
Mfg: 2/2004
The radiant cooktop on my range works but no oven functions work because the display / touchpad is dead.
Each radiant element has its own rotary control knob and they function fine.
Range has 4 seperate boards for: clock, main display, touchpad, and main control board. I’m guessing that if only the display boards were dead the touchpad would still beep when pressed, so my problem must be in the main board.
I haven’t been able to find this model # in the database, so any help or experience would be greatly appreciated.
Thanks!
Mark,
Sorry we don’t have this model number on our site yet. Should be included with the next update. We do have all the parts for it though. By the way, how old is this model? Is it still under warranty? Check your use and care manual.
Sounds like the display board is not getting any power. Since this model is so new, I can’t find a wiring diagram for it. There should be one taped to the oven, either behind the control panel or to one of the side walls. There is a safety thermostat on the back of the oven, but since I don’t have the diagram I can’t tell whether it cuts off power to the display board. Check the main board, could be a bad low voltage transformer (part of the board). By the way, this is an oven/micro combo. Microwaves have a component called capacitor, which stores power even when unplugged. Be careful with that, if you’re not sure how to discharge the capacitor, do not take anything apart!
If you do find the wiring diagram and can scan it, post it here. I’ll check it out.
- Main board (out of stock, will take about a week or more to get)
I don’t know if it’s done on purpose, but it’s very common for GE to have one model number on the appliance tag and a slightly different number (usually omitting zeros or replacing them with an *) in the parts database.
