My GE Profile dishwasher won’t drain completely. I reviewed some of the other posts and here is what I did.
[LEFT]Take off the lower spray arm ( lift up and turn counter clockwise) start the dishwasher and let it fill, when done filling push reset/cancel and see if it drains all the way.[/LEFT]
It did not drain all of the way.
[LEFT]I took off the white nut that is above the fine filter, remove the fine filter. Then the hub that has the spray tube attached to it, turn it to the right a bit and pull off that tube that runs up the back wall. Pull off the plastic screen and there is your sump. There is an insert in the sump that that screen clipped to, squeeze that and pull up, and clean it. now stick your hand down in the sump, and pull out whatever it is that is clogging the drain hole.[/LEFT]
[LEFT]I did all of this. The sump had water in it. I put some towels in and finally drained it.[/LEFT]
[LEFT][COLOR=#000000]With the insert still out I ran a short rinse cycle but the dishwasher filled with water again. This time, I noticed water coming out from the bottom of the dishwasher.
[LEFT]What do you suggest?[/LEFT]
[LEFT]Thanks in advance for any assistance.[/LEFT]
[LEFT]Bill[/LEFT]
[/COLOR]
[/LEFT]
