GE Profile French Door Bottom Freezer driving me crazy!
Problems started when the ice maker stopped making ice. After that, the temp in the fridge and freezer started to rise. After unplugging the fridge for a couple days & switching the ice maker off, everything seemed to be working fine. After about 3 weeks, the temps started to rise once again. I ran the self diagnostics (code 07) through the display inside the fridge and it gave me a failure on thermistor 2 (fresh food compartment) and 5 (freezer). I replaced both thermistors and reset the fridge through the self diagnostics (code 15). After several hours, the fridge & freezer cooled somewhat but never got down to the set temp. I ran the self diagnostics again and it failed the same 2 thermistors I had just changed. I thought that this meant the motherboard was bad & not reading the thermistors correctly. Well, I just put a new board in the other day & I still have fluctuating temperatures and it still fails the same 2 thermistors. Condenser fan running & condenser coil clean. Compressor runs for a while then turns off even though the set temps have not been reached. Evaporator fan running. :confused: :confused: :confused:
