Installed 2007. When you depress the foot pedal, the pedal remains down and the drawer does not open. I can open the compactor by manually lifting the bottom of the drawer upward at the pedal base, but the purpose of a compactor is that it should open automatically so you can use the compactor. I’ve tighten the two screws on the inside on either side of the pedal mechanism (didn’t change the situation), had a major company repair person come out and he also tightened the screws (still doesn’t work) and, finally, replaced the pedal w/a new one (at repair person’s prompting; still doesn’t work). So, I’m writing you. The Profile is out of warranty (the major local appliance company we purchased from closed) and it cost $ 619. I’m quite disappointed.Is there something I’m not doing? Is there a certain height from the floor that the pedal should be at? What am I missing about this situation? Thanks for your suggestions/recommendations.
I also found that after 2 years my GE Profile Trash Compactor (purchased in June '07), the pedal was hanging down on the left side. I searched the internet and called GE to no avail.
After a few attempts, I finally solved the problem by removing the screw on the left side and adding a metal "L" bracket, with the bottom of the L flush against the back of the front panel. That way, when you depress the pedal, the screw can’t pop out of the metal it’s attached to.
Good luck!
Dannys00
Greetings,
The door seal on my Epic Z is torn at the bottom and leaking. I suspect something got pinched in it and the rotation of the drum ripped it.
Before I order a replacement, is it possible to just re-orient the rip to the top of the door instead of where it is on the bottom. Looks like a 180 would get it away from the water, but I also just saw a replacement video that seemed to indicate there is only one orientation due to some tabs?
Any insights would be greatly appreciated.
Thanks.
MC
