Guys, our GE Microwave model: JVM3670SF02 was accidently run (won’t say who but it was the wife) without any food in it till it went dead. Since its a fairly new model, can I assume that it blew the internal fuse (no display lights are on)? Where would the fuse be located and can I get to it from the bottom myself (since its cabinet mounted)?
Your thoughts?
thanks
[SIZE=3]Unplug microwave and remove the front griddle. Once done you can get to the screws that hold the control panel on and remove the control panel. Once done you should be able to see the fuse. Hope this helps. http://www.appliance-repair-it.com/microwave-repair.html[/SIZE]
Thanks, thats just the one fuse #AP2631556 correct? Also, when you say the front griddle, your talking about the frame around the front display and push buttons? Sorry, just want to make sure…thanks
Had to replace part on Ice maker. Now it is back together and I am getting crushed ice out of crushed and cubed both. What did I do wrong?
