I have a GE Profile Arctica side-by-side refrigerator, with a digital display/control unit at the top. A few months ago, the Custom Cool drawer, which we use for meats, started freezing everything. I believe this was due to a frozen damper, since it started working after I had the power off for a couple hours. I have visually checked the damper and it works. The only problem is that the digital temperature display shows the drawer temperature as anywhere from 36 to 43 degrees, whereas a thermometer in the drawer shows it as about 32-33 degrees, which is about what it is supposed to be when using the "meat" setting. In the process, I have replaced the thermistor behind the drawer, and the main control board, with no improvement. Now I have discovered that the display assembly is replaceable. My question is "do I really have to?" or can I just ignore the temperature readout for the custom cool drawer and assume everything else will work fine? Thanks.
Related topics
GE Profile Arctica-Fridge works fine, freezer too warm | 1 | 3737 | August 4, 2012 | |
Profile Arctica too cold | 3 | 3848 | March 11, 2010 | |
temp control not reading correctly | 1 | 557 | March 16, 2018 | |
GE profile Arctica fridge help digital temp has mind of its own | 1 | 2772 | May 21, 2011 | |
Freezer too cold on GE profile | 1 | 249 | September 9, 2018 |
