GE Profile washer disassembly
[SIZE=1]My washer leaks water from the bottom. I removed the front & top panel, and balance ring. The agitator pulled right off. I am trying to remove the inner basket to get to the tub seal (I watched water slowly drip from the center seal). My question(s) are: [/SIZE]
[SIZE=1]1. How do I remove the inner tub? [/SIZE][SIZE=1]2. To remove the inner tub hub, do I remove the hub nut? (it looks like there is a smaller nut or washer inside the hub nut).[/SIZE] [SIZE=1]Since I have the covers off, I would like to replace the tub seal and associated parts. Thanks very much.[/SIZE]
