This washer will not pump the water out after the wash cycle. It is about 1/2 full and the clothes are wet. I have checked the water pump and the impeller seems to be free. I checked it with the wires unplugged and the continuity was ok. When put back and the power was turned on I get a message that a problem has been detected with the unit. If I press the help button nothing happens. I even reconnected it to the dryer thinking that might have something to do with it. It does not make any difference. This unit will not work at all. Where do I go now?? If I knew what to do I am sure I could repair or install what is needed as I am very handy with most all things. Your reply would be greatly welcomed. Thanks
thank you for you reply
Did you check the hoses from the tub to the pump and from the pump out?
How do I replace the Plastic Inlet-Air Part on the bottom of the dishwasher door?
Not sure but this may help
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208269519.pdf
