There is a code F7 and constant beeping how do I get the code off and the beeping stopped!
[U]This is a very common problem with GE Ranges contact Ge in regards to your happines with their products.
Even after replacing the expensive parts necessary it usually breaks down with a year after that because of the cheaply made parts being defective as well.
Just google search GE oven f7 code you’ll see a million complaints call GE directly and see if they’ll remedy there big mess up.
http://www.geappliances.com/service_and_support/contact/
F7 Stuck Button
[/U]1. Function pad button stuck or
2. Bad clock. Try to free stuck button or
3. Replace Electronic Range Control (ERC).
