Ge Profile
only certain buttons on the control panel activate. The start button does not work, some of the other button do work (light up)when pressed but obviously the dishwasher wont run if the start button doesnt work. ANy thoughts???
This could mean you have a worn control panel, or it could be a faulty door switch.
How hard it is to replace each one?
It’s just a matter of disconnecting the power to the machine, and removing a few screws to access the inside of the door. You may need some help holding the outer door while you’re replacing either of the parts mentioned above. If you think you may get the wiring messed up, take a photo of it with your digital camera or phone, for reference, before removing any of the wires.
Try the following. You did not include a model number so cannot see how the control panel is set up so am assuming you have a separate control panel (keypad) and a control board.
Usually a keypad uses a common line for 3 or 4 keys so this may be why only some keys work and others do not.
Connector Cleaning / Checking
Unplug the unit
Open it up
Clean the edge connector.
