— Begin quote from Waynekuy;375119
Thanks for the reply Joe. I do hear a faint click sound. When i do push on th paddles, the light of the item selected goes out and the area light also turns off.
Where is this harness located? i looked, but i didn’t see one.
Thank you for the help.
Bottled water is getting expensive. I miss using the fridge.
Wayne,
Are you sure, you did not mix up any connectors on the motherboard, when you switched them ?
Based on your post description, you most likely have a bad dispenser control board, and or a bad actuator switch.
[part]AP3202258[/part]
[part]AP3191616[/part]
Here are the dispenser interface removal instructions(from the service manual).
Once you have it dismantled, check the foil tracers on the board for damaged or dark or burnt areas, and any damaged or loose connections to the wire harness coming out of the door interior.
Good Luck,
[LEFT][FONT=GEInspira-Bold][COLOR=#231f20]Dispenser Assembly[/COLOR][/FONT][FONT=GEInspira-Bold][COLOR=#231f20]
[/COLOR][/FONT][SIZE=3][FONT=GEInspira][SIZE=3][COLOR=#231f20][FONT=GEInspira][SIZE=3][COLOR=#231f20]The dispenser assembly consists of the interface,[/SIZE]
[SIZE=3]display board, dispenser shield, and duct door[/SIZE]
[SIZE=3]functioning parts. The dispenser interface can[/SIZE]
[SIZE=3]be removed to access the display board and the[/SIZE]
[SIZE=3]dispenser shield mounting screws. The interface is[/SIZE]
[SIZE=3]held in place by 4 tabs that hold it to the dispenser[/SIZE]
[SIZE=3]recess. To remove the interface, it is necessary to[/SIZE]
[SIZE=3]grasp the bottom lip of the interface on either side[/SIZE]
[SIZE=3]and gently pull it towards you. There are 3 wire[/SIZE][/LEFT]
[SIZE=3]harnesses connected to the display board.[/SIZE]
[SIZE=3][FONT=GEInspira][COLOR=#231f20][FONT=GEInspira-Bold][SIZE=3][COLOR=#231f20][FONT=GEInspira-Bold][SIZE=3][COLOR=#231f20][FONT=GEInspira-Bold][SIZE=3][COLOR=#231f20]Note:
[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][LEFT][SIZE=3][FONT=GEInspira][SIZE=3][COLOR=#231f20][FONT=GEInspira][SIZE=3][COLOR=#231f20]The interface and display board are replaced[/SIZE][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=GEInspira][SIZE=3][COLOR=#231f20][FONT=GEInspira][SIZE=3][COLOR=#231f20]
[LEFT][SIZE=3]as a complete assembly.[/SIZE]
[SIZE=3]When assembling, insert top tabs into the top of[/SIZE]
[SIZE=3]dispenser recess fi rst, then snap the bottom into[/SIZE][/LEFT]
[SIZE=3]place.[/SIZE]
[LEFT][SIZE=3][FONT=GEInspira][SIZE=3][COLOR=#231f20][FONT=GEInspira][SIZE=3][COLOR=#231f20][FONT=GEInspira][SIZE=3][COLOR=#231f20]The dispenser shield can be removed to access[/SIZE]
[SIZE=3]the cradle switch, duct door, duct door solenoid,[/SIZE]
[SIZE=3]and dispenser LED lights. The dispenser shield is[/SIZE]
[SIZE=3]attached to the dispenser recess with 4 Phillipshead[/SIZE]
[SIZE=3]screws.[/SIZE]
[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=GEInspira-Bold][SIZE=3][COLOR=#231f20][FONT=GEInspira-Bold][SIZE=3][COLOR=#231f20][FONT=GEInspira-Bold][SIZE=3][COLOR=#231f20]Note: [/LEFT]
[/LEFT]
[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][LEFT][SIZE=3][FONT=GEInspira][SIZE=3][COLOR=#231f20][FONT=GEInspira][SIZE=3][COLOR=#231f20]The dispenser LED lights cannot be replaced[/SIZE][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=GEInspira][SIZE=3][COLOR=#231f20][FONT=GEInspira][SIZE=3][COLOR=#231f20]
[LEFT][SIZE=3]individually. The dispenser shield and LED lights are[/SIZE]
[SIZE=3]replaced as an assembly. Check model number for[/SIZE][/LEFT]
[SIZE=3]correct assembly.[/SIZE]
[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/FONT][/SIZE][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/FONT][/SIZE][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT]
[/LEFT]
