GE Range Unresponsive Keys on Control Pad
I have a GE Profile Range JGB920BEF2BB. Suddenly two buttons on the Control Pad no longer work, "0" and "Start", which are adjacent to each other. Everything else seems to work, and there are no error codes. (I need "Start" in order to use the oven and most everything else.) I opened it up and it seems clean and dry without anything obvious to fix, except replace parts. Although there may be no way to know for sure, would it be advisable to replace the front Control Panel AP3205016 (touchpad), the Control Board AP392864 (circuit board and led screen behind it), or is there something else I can do to troubleshoot?
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=JGB920BEF2BB
I do not have access to GE tech data.
If you have the tech sheet for the unit it may show the pinouts for the keypad.
You could then use a meter to check if the resistance drops to 0 ohms when those keys are pressed.
If they do then it is a bad control board,
If you cannot test this then the more likely culprit is the keypad/control panel.
If you order it from Appliance parts pros they will let you return it if it does not fix the problem. Please see their return policy.
You may also want to try the following.
Connector Cleaning / Checking
Unplug the unit
Open it up
Clean the edge connector. Use electronics contact cleaner or isopropyl alcohol.
