GE refrig need to locate the defrost timer?
My freezer coils are frozen up and I need to locate the defrost timer.I know that you can manually turn them to see if the heater is working.I starting seeing water on the floor and the food section was not as cold as it should be.This part I’m trying to locate is not showing:confused: on your parts breakdown.Thank You
There is no defrost timer in your refrigerator. The defrost cycle operates by the main control board on the back of the refrigerator.
You can use the instructions from one of our previous posts addressed to bohemian: http://forum.appliancepartspros.com/refrigerator-freezer-repair/4221-freezer-fine-refrigerator-too-warm-3.html
Here are the breakdown diagrams and Replacement parts for GE GSS22JFMDWW | AppliancePartsPros.com
My ge refrigerator is no cooling on the refrigerator side.The freezer side was icing up.I changed the mother board.Cause the condenser fan stop working .Now the board has been changed.Model #gsh25kgrbbb
IS IT THE DEFROST TIMER?
There is no defrost timer in your refrigerator. It operates by the main control board on the back of the refrigerator.
What exactly is wrong with the refrigerator?
Did you perform any troubleshooting yet?
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5245977
— Begin quote from Gene;119268
Can you tell me where the defrost timer is located and how to adjust it …thanks please GE gbs20kbpawn:mad: :frowning: :confused:
— Begin quote from charmntim;799510
You just quoted one of my previous posts which says "there is no defrost timer". In the other thread http://forum.appliancepartspros.com/refrigerator-freezer-repair/4221-freezer-fine-refrigerator-too-warm-183.html you mentioned that the repair guy replaced the main control board to fix it.
I really don’t understand why now you are looking for a defrost timer in the same refrigerator?
What is wrong with the refrigerator now?
Here are the breakdown diagrams and Parts for GE GBS20KBPAWW Refrigerator - AppliancePartsPros.com
