I have a 1.5 year old GE bottom freezer (Model: PDS22SISBRSS, Serial #: LL045527) which I realized was not cooling about a week ago. The sides and rear were incredibly hot and when I rolled it out, I noticed that the condenser fan was not running. That’s been replaced now, but there is no change: it does not cool, sides get hot and the fan does not run! From reading other posts here, it sounds like the main board needs to be replaced as well?
You are correct the board does need to be replaced, your refer is within the serial# range for the board to be replaced free of charge. Call 1-800-ge-cares and set up a service call
