Ge Refrigrator no water or ice from front door
Hello,
My refrigerator will not dispense water or ice. Ice is in the tray, but auger will not turn if on crushed or cubed. Water will not dispense. Verified that water is present at the valve. And verified that the valve is good.
The led light does work when you press the appropriate button. The ice door does open when you press either of the ice buttons.
I have been told the problem is more than likely the main control board. Is this correct?
And I did have freezer door off for moving. And did have the front control board out, but I double checked to make sure the connectors are right.
Any hints on which board I should replace?
