Hello, after moving the fridge out of the room, then back in, the freezer door is now higher at the top by about 1/4" than the fridge door, could these doors be adjusted or is a new door needed? Photo is too large to attach.
Thank you.
John
A model number may help others help you.
If the unit uses door cams on the lower hinges, I would check them.
