GE side-by-side water dispenser tube install
Hello,
I need to replace the plastic water line/tube that runs up the freezer door up to the water/ice dispenser - because it is cut at the bottom corner of the freezer door.
Anyone have a diagram and/or advice on how to remove/replace it?
Thanks!
[SIZE=3][/SIZE]
[SIZE=3]I am having the same problem with aGE model number GSS25WGPDWW.[/SIZE]
[SIZE=3][/SIZE][SIZE=3]I have replaced the valve solenoid.I have left the freezer off with the door opened for over three hours. I evenconnected a bicycle pump to the tube where it enters the freezer door, andpumped it up to 50psi. I have checked three different fix it yourself websites. No one has been able to explain how to replace the tube inside a GEfreezer door.[/SIZE]
[SIZE=3][/SIZE]
