When I turn the micro wave on the vent door tries to open but the motor is making a loud noise. When the oven stops the door tries to close and the motor makes a loud noise. Sometimes the noise will stop on its own and sometimes I have to unplug the oven to make the motor stop. Sometimes the vent door will open and close and sometimes I have to help it. The vent fan works ok just the door has problems, can I fix this problem myself? If so, how.
Ron
Hi.
Most likely the problem is bad motor assembly
[WB07X10416](https://www.appliancepartspros.com/search.aspx?p=WB07X10416)
Here are the breakdown diagrams and http://www.appliancepartspros.com/microwave-parts-for-ge-jvm1860wd001.html
Post the results.
Simon.
