I REPLACED 2 DOOR SWITCHES - Door sensing switch (AP2024337) and Switch - monitor (AP2024338) the microwave did not work. When I open the door, the display totally disappeared. I have to reset the clock. Then the vent fan, vent fan boost and the surface light works. When I operate, the microwave beep once and the light inside flickering few second then nothing happened. Please help me identify what’s next i should check. Thank you for your advice. Louis
Related topics
Help with GE Spacemaker Door Switch Replacement | 2 | 2354 | February 25, 2013 | |
GE Spacemaker xl1800 vent fan not working | 3 | 4345 | January 19, 2013 | |
GE Spacemaker XL1800 turns on when the door is open | 1 | 2877 | June 15, 2010 | |
Ge Spacesaver Xl 1800 | 6 | 2968 | September 1, 2013 | |
GE Profile SpaceMaker XL1800 Microwave does not heat. | 1 | 3889 | February 16, 2014 |
