GE Standalone Range display won't turn on
Wife was using the oven last night, and it was working fine. Turned off the oven and then shortly after we noticed that the clock on the display wasn’t on. Tried to turn it on but none of the buttons worked on the display panel behind the range.
Have flipped the breaker on/off but that doesn’t work. Gas range works fine still – just the display with all the buttons is totally non-responsive and because of that we cannot use the oven.
Any suggestions? Thanks in advance,
Tim
Tim,
Most likely the problem is a bad control board. If the range is less than a year old then it should be covered by the manufacturer warranty.
