I need to replace two receptacles on my stove. I spoke with 'John this morning. The part I need is no longer available but he said I could use part # AP207803 as a replacement; however it does not come with the wiring. He suggested I use electric wiring # AP3440556. He did suggest I contact you to see if this wiring would work. Also can we install the new parts or do we need a professional?
Thank you
