GE Stovetop gas range burners not igniting
The problem:
Front two burners do not ignite. Back three burners ignite perfectly. I have replaced igniters on all, spark switch assembly, burner wires. Problem still persists. Checked two faulty burners to see if they are getting a charge… yes they are but the charge may not be strong enough to reach the grounded metal on top of burner. Gas is flowing fine too.
Should I next consider replacing the Spark Module? Any other suggestions?
Thanks.
dave
