GE Top Load fills and drains but nothing else
Hi first time posting and novice at DYI. I hope this isn’t redundant as I have seen some similar postings but I felt like mine had some differences. Symptoms: about a year ago we noticed occasionally after pressing start on washer water would start to fill and quit after a few seconds. sometimes took 4 pushes to really get the cycle started. Since it eventually worked we ignored. Now however washer will only fill tub and once light for wash cycle starts nothing happens (sometimes we hear it attempting and other times not). When I switch to Drain/Spin it will drain water but not spin. What i’ve done: I removed front panel to get a look inside, belt appears to be in good condition. I have reset system doing the power off and lid move posted about in other threads. Once i reset it doesn’t indicate an error but I can make the issue come up again and I get an error code of 10 flashes. When I researched the ten it indicates a control board problem. Do you guys think that since I had small start button issue before combined with no spinning/agitating issue now diagnosis is definetely board problem? Or is there another troubleshoot I should try because the two issues aren’t related? Would appreciate any advice you can offer.
I would go ahead and replace the board. If you buy from this site and that doesn’t fix the problem you can return it.
Good luck.
