I have read about the Sagging Apron on this model but I can’t tell if the Apron is bent or sagging. Any clues on how to tell. The machine makes the noise when it is in all cycles but the spin. Looking at it it does appear to be scrapping metal to metal on the bottom. Also when I look for the part it says that this is the incorrect part for this model and I can’t find anywhere to get it if this is actually the issue. I have to do something. I just moved and need to wash clothes desperately. It’s been three weeks since I washed my last load and then only one because of the noise…
Did you take the front panel and top panel off so that you can check for the sagging apron problem? This part number for the kit is correct even though the APP compatability check says it’s not.
http://www.appliancepartspros.com/ge-kit-cover-asm-wh49x10065-ap4485340.html
Eric
