[LEFT]I have a GE top load washer and I believe the control board is bad. Whats your thoughts? It cant decide to put out hot or cold water. It agitates fast and slow in the same cycle. It sometimes shuts off during a cycle. What do you think the problem is?
[/LEFT]
The control assembly certainly sounds like the problem. Try changing it out and see if that fixes things. If you buy from this site and the part does not fix the problem you can return it, see the returns policy for details and conditions.
This is the model EWA6500D1WW it has 5 control knobs. and a start and stop button and a spot spray button. I’ve looked online but cant find the control board with the 5 knobs. can anyone help me out locating one?
