I have a GE Triton Model GSD6660G00SS that will not drain all off the water in the bottom. Reference this parts list- http://www.appliancepartspros.com/partsearch/model.aspx?model_id=209983&diagram_id=21847928#d21847928
After reading advice in the other posts, I have done the following:
Checked the drain lines from the pump drain assembly and the air gap assembly all the way to the disposal. All clear
Ran the drain pump (#325) in the Service Mode and can see water is pumping out and hear it draining in the disposal
Checked the turbity sensor (#321) for debris- none
Disassembled the inlet sump (#505) and checked for debris- none
Cleaned the filter fine assembly (#451)
Replaced the drain pump (#325) and still have standing water.
Should I try a new turbity sensor or do you think my logic board is bad?
Thanks for any answers you can provide!
Joe
