During the spin cycles the agitator spins but not the drum. Any suggestions?
Remove the front panel and check the engagement of the mode shifter with the drive pulley. In agitate mode, the shifter coil is energized and the solenoid is pulled up so that the cam is disengaged with the drive pulley. In spin mode the shifter coil should be de-engergized allowing the cam to engage the drive pulley so that the drum and agitator spin together. With washer off, cam should be engaged with pulley. If it isn’t, the mode shifter is faulty. If it is engaged with washer off but not when in spin mode, the motor/inverter is faulty.
Eric
Thanks, Looks like either way it’d be best to just replace.
