Age is a guess. While washing a load of towels, the tub in the washer began spinning violently, hitting the sides, etc. After inspection, it seems that a black belt that attaches to it could be the culprit (it’s definitely broken). I have no experience with appliances, but if I don’t try to fix it, it will never get done. If someone could comment on whether this belt could cause such a problem, and if so where to get a replacement belt/how to install it, that would be fabulous. Thank you so, so much.
After some googling, I believe the item in question is called a "tub dampening strap" and there are four on each machine that should be replaced at once. I’m also including some cell phone pictures for reference - thought this would make identification easier. If someone could confirm this and direct me to replacement instructions, I’d be forever grateful.
Thanks again.
Picture showing broken strap.
Picture showing general area where strap is.
