Have a GE washer that intermittently won’t spin at high speed. It seems to be when the load is small. No error codes on motor. Sometimes it will resume spinning if load selector is changed from a heavy load to a smaller load. Drain & spin will occasionally get the high speed spin to work after a failure but you have to press the start button multiple times.
Any help appreciated.
