I did check AC voltage - plugged my dryer into same outlet and it works so it has power.
I replaced the lid switch probably three years ago. BUT - when it failed - teh washer would fill and timer would run but it would not spin /agitate. So I suspect the lid switch isn’t the issue.
Sounds like the problem is a bad timer, but without the wiring diagram I can not tell you how to test it. If you do have the wiring diagram and can post it, it may help.
Any timer is just an assembly of a few switches operated by a special timer motor. You can not do any tests or bypass anything without the wiring diagram. Check inside the control panel for the tech sheet.
Y’know Gene - God Bless you!
It just occurred to me that my wife told me a month or so back that the washer "never stopped" it just kept spinning and spinning.
Told me it’s done this a "few times".
What else could it be but the timer getting ready to go "toes up"?
I’m going to order one up!
Thank you so mouch for the assistance. I appreciate it!
P.S. If the new timer would not solve the problem, you still can return it for the full refund because of very friendly Appliance Parts Pros return policy.
