GE washer stops in midle of cycle
My Ge washer will run through the wash cycle then refill with water and stop. If you push the start button again it will finish the whole cycle like nothing is wrong. This is not a constant problem, sometimes it works without any problems.
It is very hard (almost impossible) to diagnose such intermittent problems. I would keep use the washer until it will do it more often.
It just happened again. I went in to check the washer and all the lights were flashing and there was still half a tub of water.
— Begin quote from Gene;119246
You can try to diagnose it if it’s still not working. Remove the front panel, locate the LED on top of the motor (under the top cover) and watch how this LED is blinking. Post the results.
