GE Washer will not stop spinning
Greetings,
My GE Washer goes through all the cycles of a wash, however, it will not stop spinning after finishing the rinse cycle. It will just run and run in the spin cycle for hours unless you manually stop it. Any idea what the problem could be?
HI.
Based on what you describe I think it’s the bad timer.
The timer AP3775089
Here are the breakdown diagrams and http://www.appliancepartspros.com/controls-backsplash-parts-for-ge-wcsr4170d0ww.html
Post the results.
Simon.
Thanks for your help Simon. Does this type of issue come up often?
You are welcome.
Yes, the timer failure is a common enough problem.
Simon.
