GE Washer will not turn on
My GE washer has started sometimes to not come on when I press the power button. There is not a problem with the house electrical plug.
I unplug the washer for a while and I may have to do this several times. It will work for days and then stops again.
I can’t find a manual on the washer, so my husband whose an electrician can
check the washer for loose connections or broken wires.
I don’t even know how to take the front off, I sure wouldn’t want to damage washer.
Has anyone else had this problem or do you know where to find manual on this model washer.
