GE Washer Won't Complete Drain and Spin Cycle
Washer has three separate wash settings - Whites, Permanent Press, and Colors. The washer will not complete the drain and spin cycle on the Colors setting, the other two settings work fine and complete the entire cycle. It seems to get within a couple minutes of completion, and the clothes are pretty wet and heavy from not completing the spin. I’m not sure if the drain cycle did not complete, or if the spin cycle is just ending early. Thanks.
Sounds like a faulty timer. If it doesn’t fix the problem, you may return it.
http://www.appliancepartspros.com/ge-timer-washer-wh12x10527-ap5645215.html
Eric
