The wife went to turn on the washer this morning and got nothing. I checked the breaker and outlet and have power.
Any ideas?
Any ideas?
Open the control panel and look for the tech sheet inside. Check the power to the control board according to the wiring diagram and post the results.
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5130794&diagram_id=21781624
ā Begin quote from Gene;147965
Here are the breakdown diagrams and Controls & backsplash replacement parts for GE WJSE4150B2WW | AppliancePartsPros.com
ā End quote
It looks like the control ASM is no good and the lid switch is bad. Replaced both and the lights would only blink off and on.
I was scratching my head for a few moments until I picked up the old ASM and noticed a loop back connector with some wires in the plug on the right side of the old ASM. I transfered this plug from the old control ASM to the new control ASM and BINGO! works like a charm. Thanks for the help Gene!
You are welcome. Iām glad you were able to fix it.
