GE Water Dispenser not working
I have a GE model # GSS25JFPAWW that is 4 years old.
The ice maker works but the water dispensr does not.
I changed the waver valve assembly PN AP3192626 and have 120 vac at the solenoid.
The water r[SIZE=3]eservoir - a coil of plastic pipe - is not frozen.[/SIZE]
[SIZE=3]When I disconnect the plastic pipe at the bottom of the hinge/door connector splice and hit the water dispenser switch - I get a flow of water.[/SIZE]
[SIZE=3]How do I replace and/or fix this now?[/SIZE]
[SIZE=3]Thanks,[/SIZE]
[SIZE=3]Rob[/SIZE]
It’s WR49x10173, and The instructions are included with the part. I personally have not put one in yet, but heard it’s pretty easy.
So the heater didn’t work. That’s the kind of thing we have to do to get by these days. Good idea.
