I recently changed out my Natural gas user GE Stove to LP usage. I switched over the top regulator located in the upper right corner of the top stove for LP usage.
My top burners are working out fine (i changed out the brass orfices to the silver orfices), but my oven is an INFERNO!! I cannot seem to get it in working order. The flame will not tone down. What must I do to correct this?
Yes, I do have the "Technical Data Sheet" that includes the wiring information, the schematic diagram of the stove, and the Conversion LP instruction.
I followed through with everything on the conversion portion. I even tried adjusting the air shutter and turning the oven burner orfice gently until snug as indicated. (There was not included in the top burner orfices a separate orfice for the oven, there were only 4 orfices made available.)
I even tried the Oven temperature calibration that includes adjusting the oven knob to a "cooler" setting. This also failed.
I do not know how to post a copy of this data sheet to this forum…
