Thank you for your reply. My GE side by side refrigerator is freezing everything in the fresh food compartment especially in the bottom shelves, drawers and door. I was told that it’s probably the thermostat. When I looked at the chart in the temperature control box, there was a defrost timer and a cold controller. Which one should I change. The 1st thing I did was lowering the setting to the lowest dial (1); but that did not help. The compressor kept running constantly non stop. The temperature in the freezer compartment seems OK although I did not get a temperature reading. I can also feel a very cold breeze coming from the back of the refrigerator even when the door are shut.
— Begin quote from mmpusa;201606
The fresh food compartment is freezing. I think it’s the thermostat. Do I need to replace the defrost timer or the cold controller
Did you try to adjust the temperature settings? What is the exact temperature in the freezer?
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=203790
