General Electric washer will not agitate or spin
[SIZE=7]This washer will not spin nor agitate and there is one other problem that i have with this problem that is that i can’t open the case up to get to the motor. I am almost sure that it may be the drive coupler that may need replacing it also makes a kind of grinding sound that i have never heard before, Can you tell me how to get to the area where the problem is, I mean just how do you take the top of the washer off because i am having some problems taking the top off.[/SIZE] [SIZE=7] I might be wrong in assuming that the problem is in the drive coupler so if you can please advise me as to where to look.:mad:[/SIZE]
Might be the clutch. The front is held on by 2 spring clips about 3 inches in from the edge. slid a putty knife between the top and front. Push the putty knife in to release the clips one at a time.
