I have a Gibson FH15M2WKAC and was wondering how to obtain parts for it. temp adjust knob is broken, other things. Don’t know exact age but wondered if it’s worth fixing. Thanks!
I also could not find any info on this model.
Probably best to contact the parts folks at AppliancePartsPros.
They have access to more part info than is available on the site and also a lot of knowledge on what/where to get parts.
Is it worth fixing depends on if a part is available and at what price.
Also what shape the unit is in.
[COLOR="Blue"]
temp adjust knob is broken, other things[/COLOR]
If it is just the knob then that is not a biggy as you really do not need the knob. You could set it using a thermometer in the freezer.
Adjust it let it run for at least 12 hours then check the temperature. It should be between 0 and 5 degrees F.
Also it should be cycling and not on all the time.
But if it is the thermostat then finding a replacement may be a problem.
Also what "other things" need replacing.
