gibson washer won't drain
Hi, My Gibson washer stops at the spin cycle, leaving most of the water in it.
Tried different settings.
Its not the lid switch, checked that.
It agitates fine.
Took it apart, unhooked hose closest to me coming from tub and it drained the water, took other hose off going to outside and no water came out.
Did not see anything clogging it.
little fan thing turns fine.
Will I need a new drain pump ?
Its less than 5 years old, and only do 6/8 washes a year in it.
imho should last longer than that.
Any advice is appreciated
Thank you
Thank you so much guys, did a google search for my washer problem and found this helpful site. Did what you said and found about a dollar worth of change an underwire for a bra as well as a small part from a zipper lol. Now my washer is running like new again thanks again.
