my fridge has a top freezer and bottom fridge compartment. water leaked into the bottom fridge. I defrosted it, but now there’s water leaking into the bottom fridge again. What should I do next? Thanks for your help!
Hi,
** I defrosted it**
For how long?
12-24 hours with the doors open should provide a good defrosting.
GTR22HBTARBB
Please recheck.
https://www.applianceaid.com/model-number.php Some model# helps.
A restricted defrost drain could easily allow defrost water to leak inside. I couldn’t look up what yours looks like as the model# didn’t seem to work for me…but this may still help:
https://www.applianceaid.com/refrigerator-leaking.php
jeff sr.
Wilsonjiaho, thank you for your question. Based on the information provided, the defrost drain under the evaporator is clogged up. This would need to be thoroughly cleared all the way down to the compressor section.
Fantastic! Now that I know how to fix the clogged sink, what tool do I need to clear the drain all the way down?
Hi all,
This might help…
https://www.applianceaid.com/refrigerator-leaking.php#inside
A turkey baster, a bicycle cable have been used to help clean/flush the drain out.
jeff sr.
